atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
stanvw
Jan 21, 2013Aspirant
Hi,
I have exactly the same issue with security when connecting the WN2500RP to the DGND3700 with any type of security switched on. This is an issue on both 2.4 and 5Ghz options. It works if all security settings have been disabled but that is no option for me. I don't believe ACL is a workable solution as you would assume two Netgear products should work together without jumping through hoops. Any idea when this will be fixed with firmware upgrade?
