atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
bentanvil
Feb 23, 2013Tutor
Finally we have a solution!!! :D
Netgear have finally replaced my DGND3700 with a DGND3700v2 and all of my problems have gone.
Both units now connect perfectly WITH security on BOTH bands. Looks like the issue was with the crappy v1.
I suggest anyone with this issue gets onto Netgear and get them to replace your v1 with a v2. It may take them a year to look after you, but that's Netgear for you.
Cheers for your help Scubbie. You were right all along. ;)
