atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
Scubbie
Feb 23, 2013Apprentice
Excellent result there.
Sadly it does take them a little time to resolve things though.
I did like the specifications of my DGND3700 (v1) but sadly it was let down by the internal specs in my case.
I haven't had a v2 to be able to compare the two. However you should like the new GUI. Do download the Netgear Genie app to your smart phone, if you have one.
