atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
Rocks065
Jan 18, 2014Novice
Change your firmware on the DGND3700 back too V1.0.0.12_1.0.12
and it should work fine with both with WPA2-PSK (AES) working
