atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
Rocks065
Feb 05, 2014Novice
atkinsonline,
Change the firmware on your DGND3700 modem back to version V1.0.0.12_1.0.12
and redo setup with security WPA2-PSK (AES) and awl should be good
