atkinsonline
Apr 10, 2012Aspirant
Cannot connect on 5GHz
Hi, I have a DGND3700 router and just bought a WN2500RP to extend it. Both are are on latest firmware. I went through the normal set up using TPS and it connects and shows the 2.4GHz connection. I...
bighowy
Nov 22, 2014Aspirant
Im using the r6100 router with a wnda3100 usb dual band adapter
I have never been able to get 5 gig until I went into device manager and disabled the built in wifi adapter. Now it works every time. Using win7 64 bit Pro
