DrunkenSoldier's avatar
Sep 29, 2015
Cannot connect to network wn3000rp
So i have windows 10 and have no idea if that does something to the wifi extender. I go to wifi manager and try to connect to (name)_EXT. I stare at the wifi extender and the LED for connecting from wifi repeater to device turns on and turns off. And it shows that it say "Cannot connect to network" I tried this muiltiple times and still no luck.
  • nhann's avatar
    nhann
    NETGEAR Employee Retired
    Hi DrunkenSoldier,
    Is this your first time setting up the WN3000rp? The extender does not depend on which operating system your computer is running.
    You can also test the Extender internet connection by wiring an ethernet cord from the extender to your computer.
    Please press and hold the Factory Settings button on the side panel for 7 seconds.
    The Extender resets, and returns to its factory settings.
    http://www.downloads.netgear.com/files/GDC/WN3000RP/WN3000RP_UM_1Feb13.pdf
  • Hi
    So i have the same problem and the same question: Why should the operating system have anything to do with the wifi extender's function? I thing it's even interfering with the connection to the main wifi access point.
    Netgear publishes a list of devices with Windows 10 support:
    http://kb.netgear.com/app/answers/detail/a_id/29490/~/netgear-product-support-for-microsoft-windows-10
    Unfortunately, the wn3000rp is not on it. Hhhmm......
    Deconnection and reconnecting, power off and on, new firmware...... nothing does help at this point except - switch off the extender.
    • nhann's avatar
      nhann
      The router and extender functionality are not dependent on what operating system you have.
      Which router is connected to your router?
      Is the router updated to latest firmware?
      Please try resetting the WN3000rp to factory default.
      Press and hold the Factory Settings button on the side panel for 7 seconds.
      Also place the WN3000rp in the same room as your router and test the connection.
      Another option is to change the WiFi channel on your router, see
      http://kb.netgear.com/app/answers/detail/a_id/23783/~/improving-2.4ghz-wireless-performance-by-changing-channel
        Dear nhann
        Thank you very much for your reply and suggestions. These are the data ;
        Extender: wn3000rp
        Firmware: V1.0.2.64_1.1.86
        Router/Access Point: Swisscom “Centro Grand”, obviously an OEM version of some Pirelli BBS router.
        It seems your suggestions did help a little, at least for this day. My computer was able to connect to the extender’s network after its factory reset. However, the connection speed is not as good as it should be and it’s not stable at all. Connection speed varies from 10 Mbit/sec (my nominal speed provided) to app. 2 Mbit/sec.
        I also did set the channel manually to 11 which was least occupied (out from 1, 6, 11). I think this did not help any further.
        Let’s see what the next days might bring in terms of extended connection.
        By the way: Why is there a list of Win10 supported devices, if the operating system do not depend on the operating system? Just curious.....
