Liddle
Jan 16, 2018Aspirant
Can't find Netgear Extender EX6100 wifi network
Neither my Apple notebook nor my IPhone can see my Netgear EX6100 network; so i can't set it up. I tried the hard reset on the Netgear, moving it, unplugging it, etc. Should I try a buying a different model Extender. Do you think the extender is broke. It is several years old, and I used it on my previous home router.
(My current home WiFi is Sagemcom fast6250, if that makes a difference.)
Hi Liddle,
Check if you can connect a Desktop or Laptop wired to it and gain access to its setup screen.
- jvasanth1984Virtuoso
Hi Liddle,
I would like to know if you perform reset when device is powered on. Please follow below link on how to reset the extender.
https://kb.netgear.com/26082/How-to-reset-my-EX7000-to-factory-default-settings
- LiddleAspirant
Yes, multiple times it was reset. I also moved the location of my notebook and extender. Also tried two different browsers, Chrome and Safari. And reset my computer.
Hi Liddle,
