CCDB's avatar
CCDB
Connect Netgear 6100 Extender to PACE modem/router
I have configured the EX6100 to the WiFi provided by my local cable company with the required security. Then, I connected to the extended SSID using the provided password. Connection was successful, but when I tried to access a web page, either nothing happens or the page cannot be found.  Any suggestions?  Thanx, CCDB
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello CCDB
    Is you device getting a IP address when connected to the extender?
    DarrenM
    • CCDB's avatar
      CCDB
      Hi DarrenM,
      Yes, when connected to the extender I have IP address 192.168.1.128.  Security is WPA2 PSK.  My PACE modem/router has Router/Gateway Address 192.168.1.254 and authentication type WPA2-PSK (AES).
      Thanx,   CCDB
      • DarrenM's avatar
        DarrenM
        Have you tried to factory reset the device and try setup again? Also make sure the extender is on the latest firmware.
        DarrenM
