pbfree
Apr 20, 2015Novice
Connecting to Verizon Router
Hi, I moved my Extender from a Brighthouse service to a Verizon FIOS service with the supplied equipment. I reset the extender to factory settings to avoid confusion. I set up the extender and the d...
lurzan
Apr 20, 2015Novice
Login to the extender settings using www.mywifiext.net and check the connection status. That will give you clear idea if the extender is already connected to router or not.
