Trickyt57
Aug 04, 2015Tutor
Daisy chaining Wifi Extenders, Wifi Repeaters and Wifi Range Extenders
I read somewhere that it is not possible to Daisychain WIFI range extenders. Is that correct? How do Hotels do it to get wifi in every room? I want to extend my network to further away than the...
netwrks
Aug 04, 2015Master
Hotels typically use numerous Wireless Access Points. I don't think you can Range extend off an range extender.. The IP issue, may be the default IP Address on one your devices. Range extending is generally hit and miss, and lots of disapointment. You sacrifice throughput.
The best way to extend your network is using ethenet (CAT5e or CAT6) to connect an Access Point to your network router. Much better than Range Extender's. I beleive that your Netgear WNDR4000 Router can aslo be converted into an Access Point.
