tdnishio
Apr 26, 2021Aspirant
Device: Red light stays on N300 EX2700 even if plugged in next room
Which red light? It has several led's.
What router is the EX2700 connected to?
Did you set it up using wps or using the installation assistant?
- tdnishioAspirant
Red light stays on the Device.
Router is from my internet provider Consolidated Communications.
I believe it was installed using Netgear's installation protocol.
If you need more clarity than what I have provided, please let me know, what more specific you need.
tdnishio wrote:Red light stays on the Device. ----Which led? That's key.
Router is from my internet provider Consolidated Communications.---that told me nothing. What actual router is it?
I believe it was installed using Netgear's installation protocol.----which protocol? there's more than 1 way to install it which is why I asked.
If you need more clarity than what I have provided, please let me know, what more specific you need.----Yes I need more clarity. Actualy details helps. I'm not there to see whats going on or what you did so you need to be specific.
