DanR01
May 20, 2017Aspirant
Duplicate 192.168.1.1 address causing wifi disconnect
There is a bug in the range extender where it is announcing itself as a router by sending ARP packets with duplicate 192.168.1.1 addresses. It is being used with the Netgear Nighthawk router D7800 model. This causes frequent disconnects with Apple devices. Linux and Windows are unaffected. Switching off the extender solves the problem.
It is disappointing that Netgear products do not work properly together. Does anyone have a solution?
Wireshark trace:
Frame 706: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface 0
Ethernet II, Src: 16:da:43:0b:c3:58 (16:da:43:0b:c3:58), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
[Duplicate IP address detected for 192.168.1.1 (16:da:43:0b:c3:58) - also in use by b0:7f:b9:43:ef:2b (frame 705)]
[Frame showing earlier use of IP address: 705]
[Expert Info (Warn/Sequence): Duplicate IP address configured (192.168.1.1)]
[Duplicate IP address configured (192.168.1.1)]
[Severity level: Warn]
[Group: Sequence]
[Seconds since earlier frame seen: 0]
Address Resolution Protocol (request)
Change the IP address on either the D7800 or the extender. Both use static addresses, so you may have inadvertently set the same address on both devices.
- DanR01Aspirant
I've changed the router IP address to 192.168.2.1 and the problem persits with dupicate ARP requests.
I can't see the picture until the moderators approve it.
Is the router complaining about 192.168.1.1 or 192.168.2.1?
You changed the router's subnet, so you should change the extender's IP address to be in the same subnet.
