Olivedrab
Jun 16, 2022Follower
EAX20 Mesh Extender stuck during setup
Trying to setup an EAX20 extender to go along with our CAX30 modem/router using the latest version of the Nighthawk iOS app.
Every time I had tried to do so, the EAX20 gets stuck on trying to connect to the 5G signal (screenshot attached). I had left this overnight in the past and no luck.
I have tried closing the app and restarting the process but then the app is unable to join NETGEAR_EXT network to even initiate the process. I have to reset the extender to attempt again but get stuck at connecting to 5G each time.
Please help! Thanks!
1 Reply
Did you try setting it up using wps?
Or try using the browser based installation assistant?
