fsamuel's avatar
fsamuel
Ethernet cable out not working
I just bought a EX3700. The only reason is because i have an interactive TV box that only takes ethernet cords for some reason. My router is in the other room so i don't want a really long cable going between rooms. Problem is that the wifi works fine but the ethernet out connection doesn't (which was the main reason of buying the thing) any ideas?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello fsamuel
    When you have the TV box plugged in can you log into the wifi extender and see if it is showing up as a wired device?
    DarrenM
    • fsamuel's avatar
      fsamuel
      yes, i have done that and i do believe that it does show up. But the problem is that there doesn't seem to be a actual internet connection between them. The interactive box does not work. but when i plug it back into my modem and reset... it does work.
      • DarrenM's avatar
        DarrenM
        Hello fsamuel
        Is there any type of internet settings you can get to in the box where you can see a Ip address maybe if you set a static 192.168.1.x address it will connect.
        DarrenM
