Fraydumfries's avatar
Fraydumfries
EX2700 n300 range extender
I have an ex2700 router extender and have just tried to connect to a new router. However, it won't bring up the Web page to login. I have factory reset and checked the address but I get an error message. Can anyone help?
  • plemans's avatar
    you factory reset?
    And it shows the the netgear_ext option?
    did you try 192.168.1.250
    • Fraydumfries's avatar
      Fraydumfries
      I did factory reset the extender and it was showing the netgear ext but wouldn't connect to the website.  What is 192.168.1.250?
      • plemans's avatar
        that's its default ip address if its not setup (as then the router would assign one)
