ArsyMarci's avatar
ArsyMarci
EX2700 seems to have caused issues with my wifi
I have a Sky Q hub but have always had one room in the house that is a bit of a wifi black spot.  As we are in lockdown and it is my sons bedroom that is affected, I bought a EX27200 extender, plugged in, set up and all seemed ok.  After a couple of hours all wifi connectivity was lost upstairs, both with and without the extender.  We now have intemittent wifi, literally only lasting up to a minute at a time if we can get it at all upstairs.  I have tried rebooting the router and factory resetting the extender.  I also tried updating the firmware but couldn't establish what the latest version available acutally is.
My router uses 2.4ghz and 5ghz, have I bought the wrong extender?
Can anyone help please?  Thanks
  • Only once lockdown is lifted apparently! Thanks for trying to help 🙂
  • plemans's avatar
    ArsyMarci wrote:
    I have a Sky Q hub but have always had one room in the house that is a bit of a wifi black spot.  As we are in lockdown and it is my sons bedroom that is affected, I bought a EX27200 extender, plugged in, set up and all seemed ok.  After a couple of hours all wifi connectivity was lost upstairs, both with and without the extender We now have intemittent wifi, literally only lasting up to a minute at a time if we can get it at all upstairs.  I have tried rebooting the router and factory resetting the extender.  I also tried updating the firmware but couldn't establish what the latest version available acutally is.
    so the wifi doesn't work even if the extender is unplugged?
  • Not any more :( Intermittently at best, and even then it’s very very slow
    • plemans's avatar
      If the extender is unplugged and you're still having issues, the extender isn't the issue. The router is.
      Mabye try factory resetting the router and re-install it.
      What router is it?
      • ArsyMarci's avatar
        ArsyMarci
        I think it must be. I’ve tried reboot and factory reset and it’s no better. It’s a Sky Q Hub - model ER115.
