titus46's avatar
titus46
Tutor
Mar 05, 2017
EX2700 unable to connect on Castlenet CBV734
Hi,
I tried to connect my EX2700 on Cable router CBV734... Not possible !! With wep security, wpa-psk tkip, wpa2-psk aes or without security give same result : never Led router connexion become green. I tried to connect any open networks around; no problem !!
I have an old Netgear WGR614. I have changed router mode to gateway mode and  connected WGR614. Now I can use WIFi router and extender !!! What is the problem with Castlenet CBV734EW ?  I will be happy if anybody can tell me why...
Have good day.
  • Bonjour tout le monde,
    Le problème n'a tjrs pas de solution (ou réponse) pour l'instant.
    Je ne sais pas pourquoi le CBV734EW n'accepte pas la connexion
    alors que WGR614 ne pose aucun pb.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Titus46
    Did you try to change the wireless channel of that router?
    DarrenM
    • titus46's avatar
      titus46
      Tutor
      Hi DarrenM
      Yes I do. I tried channels 1, 4, 6, 11... no change
      • titus46's avatar
        titus46
        Tutor
