Rondo457's avatar
Rondo457
EX3700 connected but no internet
  • EX3700. Went thru Network Genie numerous times with Netgear. Factory resets.
    Netgear software indicates successful install. All lites on extender are green. Device lite turns green when _ext network selected.  Spectrum Internet with SagemCom router. Spectrum
    tech people have looked at system with no success.
    • plemans's avatar
      if you hardwire into the extender, does it work?
      Are you able to pull up the extenders gui from a browser (not genie)? mywifiext.net
      What firmware do you have installed to the extender?
      What sagecom router/combo device (model)? Does it use a smart connect function (one ssid name)? if so, shut it off.
      • Rondo457's avatar
        Rondo457
        Hardwire into extender does not work.."unidentified network"....no internet
        /all lites green/ same  response as wireless.
        Extender GUI 192.168.1.250 does work from Google/Chrome
        No firmware installed...straight out of the box.
        Spectrum Sagemcom Router/ 802.11ac wave 2-askey router
        Model# RAC2V1K. No smart connect function. I suspect this extender
        model has been around several years.   Thanks again.
        Thanks
