Mystrigue's avatar
Mystrigue
Ex3700 connection failure
Using an EX3700 with web browser setup. I am able to go through the setup wizard but it refuses to connect to my 5G. I know the password is correct. I have done the factory reset and tried again with the same result.
  • plemans's avatar
    What router do you have?
    What firmware is on the extender?
    It connects to 2.4ghz fine?
    • Mystrigue's avatar
      Mystrigue
      Hi I'm connecting to a Hitron CGNM 2250 modem. During setup connection to the 2G appears to work, but the extender doesn't provide internet access for either bandwidth. I'm not sure about my firmware.
      • plemans's avatar
        Did you follow the wps method of install or using the installation assistant?
