Bandito
Aug 06, 2016Luminary
EX6150 Getting a 404 Error at the End of Set Up
I recently purchased an EX6150 WiFi extender and went through the original configuration a couple of times successfully, but then checked and found that there was updated firmware available. So I up...
- Dec 17, 2016
I had this same problem. The reason I was getting kicked out of setup was my cable modem/router was reassigning my Netgear extender a new IP address during setup. Since I was accessing my extender through its default IP address ,(In my case, 192.168.1.250) once my cable router gave my extender a new IP address, I was given the 404 error or a timed out error. [Fiddler] The socket connection to 192.168.1.250 failed.
ErrorCode: 10060.
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.1.250:80The solution is to locate your extender's new IP address that your cable router gives to it. I went into my cable router, using my browser, and saw what addresses it was giving to my connected devices and simply guessed as to what the new address would be. My (Comcast) cable router IP address is 10.0.0.1. It gave my extender the IP address of 10.0.0.2. Once I guessed this and entered that address into my browser, I connected to my now setup router and all was wel.
Model: WN2000RPTv3|WiFi Range Extender
Bandito
Oh, I forgot to include some information, so here it is.
When the 404 error occurs, the extenders disconnects both the client and the router networks. So if you're connected to the extender at the time, it throws you off. It didn't seem like a full reboot as the connection LEDs both relit within a few seconds, but it makes you think that the setup didn't succeed because of this.
DarrenM
Aug 09, 2016Sr. NETGEAR Moderator
Hello Bandito
I will have this looked at and get back with what I find out about this.
DarrenM
