semola1's avatar
semola1
Tutor
Jan 29, 2018
EX6150/AC1200 WiFi range extender
Hi All,
I have a little problem with my Ex6150 Range extender. I have configured it creating 2 new SSID (adding a "_1" to router original SSID name).
In total I have 4 SSID (2 for 2,4Ghz and 2 for 5Ghz network).
I have also connected one ethernet cable on the extender connecting a fixed PC to it (the ethernet cable is connected to 5ghz WiFi).
If I connect a wireless system with the 2.4 Ghz SSID generated by the extender, it doesn't visible from the Fixed PC (ping, configuration page, etc.) and, in general, from all the network. If I connect it to original SSID (2.4 Ghz) I don't have any problem.
Could there be any wrong settings?
Thanks, Marcello
  • Hi semola1,
                          What firmware version are you running currently on your EX6150? Do check for update if any and see if that resolve your issue.
    • semola1's avatar
      semola1
      Tutor
      I'm updated the firware with last version (V1.0.0.34_1.0.69) about two weeks ago, but the problem is still there.
      Marcello
      • jvasanth1984's avatar
        jvasanth1984
        Virtuoso
        Hi semola1,
                               Try to reset and reconfigure the extender to see if you still witness the issue.
