timothybarrier7
Dec 15, 2018Aspirant
EX6150V2 / AC1200
Have gotten all the way to "Log into new EXT network with whatever devices with wifi you want"
When I go to sign in, all I get is "Can't connect to this network"
Ive factory reset, been over ethernet connection, everything multiple times. And if I get to this point it STILL does the same answer....Any ideas? My laptop is windows 10, my android is the cell, etc.....but nothing will get past above mentioned comment.
If you used the WPS setup, the network should use the same password as your router network.
Have you tried that?
- timothybarrier7AspirantYes. Everything has setup properly I believe I've even got the Netgear genie app showing me that everything is hooked up it's just when I go to sign on to the actual site for the extender it says internet is not available. It's mind-boggling to me the only thing I can think of is the MAC address and what not is not in my router but every time I go to get in my router that's through spectrum Askey model I can't sign in tells me unavailable the site
Are you connecting to the extender network when you browse to www.mywifiext.net?
