jerrychen_cn
Oct 29, 2015Guide
EX6200 connection issues with the firmware version V1.0.3.68_1.1.104
I have an ex6200 running in AP mode connecting with a R8000(nighthawk). Before I updated it to the firmware version v1.0.3.68_1.1.104, it had worked very well. I means it was steady and i was able to connect to it with the maximum speed of about 867Mbps in 5Ghz ac mode and close to 300Mbps in 2.4Ghz 802.n mode. However, when I updated it to the latest version today, I can't connect to it with the maximum speed any more. Instead, the maximum connection speed is alway 54Mbps or less. Although I have reset it and reconfigured it many times, the issue is always existing.
Anybody can help me out?
OK, well it may be worthwhile trying the previous firmware version again.
- reggielee31Aspirant
I have the same problem
updated to V1.0.3.68_1.1.104. wifi speed only 54Mbps or less showing in my devices. I downgraded to 1.0.1.60.1.1.98. AC speed back to 866
- Babylon5NETGEAR Employee Retired
Have you tried different wireless encryption methods, excluding WEP / TKIP? If you temporarily disable encryption do you still connect at a lower rate?
- After I reset it, i have attempted to connect to it by default SSID NETGEAR_EXT5G or NETGEAR_EXT without any encryption. But the connection speed is the same.
When you say that you reset the extender, do you mean a factory reset? If not then that may be worth a try. Otherwise, you could try reverting to your previous version of firmware, you simply upload it manually and ignore any warnings that it is older than the current firmware.
