noboundaries
Jun 30, 2015Guide
EX6200 need to reboot every 5 days!!
Latest firmware sees the EX6200 needing a reboot every five days, why?? I have been waiting for netgear to send a returns advice but nothing received, this is month three.
Also with the new firmware (latest) the 2.4 Ghz light is orange then it just doesn't connect other than doing a reboot. Then it fails all over again.
If its not fixed I am going to Lynksys, this is nothing more than rubbish.
Fix it!!
- MetzgerGuide
Every 5 days - you are pretty lucky! It's every day for me. See this thread:
Have you found a solution?
- Good signal, just got back on the air / network, gone again. Back to factory settings and original firm ware. Now cant log in to the extender GUI, this just keeps on getting better.. Connected direct to ac netgear modem /router
- FairytailVirtuosoHow far by the way is the extender from the router? Do you still get good signal strength from the main network on the location of the extender?
- Yes, I have even loaded two previous firmware. I previously spoke to Netgear Support and they said will do a return of hardware, nothing, I am moving to Lynksys if not resolved.
- FairytailVirtuosoHave you reset the extender after the firmware update?
