bzyc
Nov 27, 2021Tutor
EX6250 Mesh Extender doesn't work after NightHawk app update
Hi folks, the most recent Android Nighthawk app update made me unable to use my mesh extender EX6250 anymore for some reason. I've since factory reset the mesh extender, and tried to reconnect, but ...
- Nov 28, 2021
Here's a video of how to use the installation assistant. the manual also goes over it.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
Nov 27, 2021Guru - Experienced User
Try factory resetting the extender and then set it up using the installation assistant and NOT wps.
- bzycNov 28, 2021Tutor
Thanks plemans . Can I please check, when you refer to "installation assistant", do you mean the Nighthawk App or something else?
- If it's something else, can you please pass me the URL for it?
- If it's the Nighthawk App, then that's what I'm having trouble with. The Android Nighthawk app closes down everytime i get to "Personalise Settings" during setup, so I'm never able to complete the setup.
Thanks in advance.
- plemansNov 28, 2021Guru - Experienced User
- bzycDec 10, 2021Tutor
Thanks, walking through the instructions in this video solved it, thank you!
