adamslater's avatar
adamslater
Follower
Sep 13, 2016
ex7000 access point or extender
I cannot stay connected on my ps4 with my ex7000 I have it setup beside my ps4 with a lan connected to it. It is currently in extender mode. Would it work better if I moved it and connected it to my router and made it an access point instead? After about 30 minutes my ping goes way up and lose my connection.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello adamslater
    It would be more reliable for gaming if you made it a AP and connected it to your router via ethernet. But you may want to try and change your wireless channel on the router to see if that helps the connection.
    DarrenM
