jbondage
Oct 23, 2015Aspirant
EX7000 LEDs Blinking
I have a Netgear EX7000 Nighthawk range extender that has been set up for about 4-5 months now. It has worked great up until now. I noticed the WPS, 2.4ghz and the 5g leds are blinking on it. I pow...
jbondage
Oct 28, 2015Aspirant
While I was on the phone the other day with someone from tech support to do a hardware check, the range extender was in the same room as the router (2 feet from it in fact) and it was still blinking.
Now that I have updated the firmware on the router, yesterday morning and this morning, the actual router had to be reset because the wifi just stopped working. In fact, before I power cycled the router, the main wifi SSID wasn't even showing up when I a wifi device in the same room as the router.
The lights on the extender still blink even after all firmware updates. After I power cycled the router this morning, I had to reconfigure the extender because when I tried to connect it to, it came up and said it wasn't connected to the internet.
Something tells me that there may be a bug in this device that hasn't been figured out yet.
nhann
Oct 29, 2015NETGEAR Employee Retired
Hi jbondage,
You mentioned that the router had to be reset. Was this a complete factory reset to defaults?
Which router are you using with the extender?
" In fact, before I power cycled the router, the main wifi SSID wasn't even showing up when I a wifi device in the same room as the router. "
Can you please clarify where you were checking the SSID? When you have another device in the same room as the router, you do not see it in the Extender's setup to select a WiFi network? or when on your computer, you do not see the router's SSID?
Do you have access to the internet when just connected via an ethernet cord to your computer?
- jbondageOct 30, 2015Aspirant
I have not done a factory reset on the router because there are setting that Netgear Support made that I don't know what to put back. I am using a netgear WNDR4300 Router. When I was trying to check the SSID as previously mentioned, I was in the same room as the router, about 1-2 feet away.
This morning, there was no internet at all. On the desktop computer that is connected with a LAN cable, I had no internet. I opened a browser to connect to the router's set up page and I couldn't even access the router. I put in 192.168.1.1 and nothing would come up. I had to power cycle the router all over again.
- nhannNov 02, 2015NETGEAR Employee Retired
Hi jbondage,
Thanks for the clarification. It sounds like more of an issue on the router itself and not the extender, based on the descriptions you provided.
The router is using updated firmware and is now losing its WiFi network until you power cycle the router.
Please contact support and verify with them if it is a hardware issue:
- jbondageNov 12, 2015Aspirant
Sorry for the delay in responding. The router is still dropping the connection. Just tonight alone, while sitting at the desktop computer where the WNDR4300 router is sitting, I watched it drop out 3 times. The internet like goes out, along with the wi-fi signal lights.
I've contacted netgear before about whether it was a hardware issue and all i got was, we'll help you if you give us 120.00 for gearhead service. This router is only a couple of years old. And has already been replaced by Netgear a couple of times.
I'm getting frustrated with it because I can't get any help with what appears to be a possible firmware issue or a device issue unless I pay for help. That shouldn't be the case.
