mrund's avatar
mrund
Follower
Mar 08, 2016
EX7000, loss 5Ghz SSID / all connected devices
Been using my EX7000 as an accesspoint, both 2.4Ghz and 5Ghz for clients.
The EX7000 is connected with wire.
Once a week or every second week at least, all clients connected to 5Ghz will loose the connection and the SSID is not visible any more.
Only a restart solves the problem, also seen the 2.4Ghz drop all connections and SSID gone, once but never again.
Using two different SSID, one for 2.4 and one for 5ghz, so I know which one that disappears.
As I have it connected to the wired network as well, I can log in and do a restart.
Currently at: Firmware Version V1.0.0.38_1.0.91
Any suggestions?.. Did notice that the R7000 had the same problem when I searched the forum, but no luck with a workaround/fix.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello mrund
    I would try to change the wireless channel? also I would try a factory reset on the EX7000 see if that helps with the issue.
    DarrenM
