schumaku's avatar
schumaku
EX7000 V1.0.1.78_1.0.140 Update Observations: Smart Connect Oddities, Release Notes
Long-term operating EX7000, operating in Access Point Mode (with anEthernet uplink), updated from 1.0.0.32 to V1.0.1.78_1.0.140 (flawless that far).
One new feature seems to be Smart Connect, in my understanding it should set the same SSID and security on all radios, and enable 802.11k information to wireless clients. So went to the Wireless settings, ticked Smart Connect, and wanted to apply.
Why ever, the UI does ask to connect the extender to the "same" network ... this loks to me like a check only when operating the EX in extender mode, not in AP mode. Did not had the but to tick and [Continue], no time to bring a working set-up into risk:
The description does not provide sufficient information about the feature overall:
More fun is in the release notes - yes, I'm complaining about the RN provided - but this amount of fixed security bugs is overwhelming - it would be great to have a list with the effective fixes, the CVE resp the Netgear PVN information:
Anyone from Netgear please - need some light at the end of the tunnel.
    • Murfinva's avatar
      Murfinva
      Updated to latest Firmware 1.0.0.158 , connection dropped from 433mbps to 90 mbps (I Have a 1GB Dual band Netgear router). Tried 1.0.0.148 same thing, went back to 1.0.0.136 now back to the 433mbps. What a waste of time. Read all the release notes, folowed the instructions. DOES NOT WORK.....
      • schumaku's avatar
        schumaku
        That's not an EX7000 unless I'm very wrong. The issue the more and more users are expereincing on EX7000 V1.0.1.78_1.0.140 are different. You might want to open a dedicated thread on the EX7700 (wild guess) issue please.
  • Retired_Member's avatar
    Retired_Member
    Hi,
    I've also been having nothing but problems with my EX7000 (used in AP mode) since the V1.0.1.78_1.0.140 firmware upgrade.
    I've just disabled the "Smart Connect" feature (which I can't see how this would be relevant in AP mode anyway...) and so far it seems to be working OK.
    Hope that helps.
    • schumaku's avatar
      schumaku
      Curious how you had it enabled - we are promped to connect to a wireless, and there we stopped the process (as using a LAN connection of course)?
      Smart Connect does balances your the WiFi connections to the router/AP on two or more radio bands. Your router uses Smart Connect to choose the best radio band for your device to give you the best WiFi performance. For Smart Connect to work, all radios invovled must use the same WiFi network name (SSID) and network key (password).
        Retired_Member
        OK, I realise my comment about Smart Connect might be ill-informed... anyway, seems much more stable since disabling it.
        I'll post back if I get more problems.
        Oh, and NETGEAR, if you're listening: the pop-up window every time I login to the EX7000 web UI is super-annoying!!
  • Stopped working as extender. Devices connected to extended network cannot receive IP addresses from DHCP server. both 2G and 5G bands behave similarly. Going back to 1.0.0.42 (to have DFS working), everything working again.
    Avoid this upgrade if you use EX7000 as range extender.
