maddavo
Jul 31, 2015Tutor
EX7000 Virtual MAC Address problems
I want to disable the EX7000's allocation of virtual MAC addresses to devices on my network but I cannot find anywhere how do do this. I am coming to the conclusion that it is not possible. The virtual MAC addresses are causing me problems.
I have a DHCP server on my network. The DHCP server allocates reserved IP addresses to devices on my network. Some devices are wired, some are Wifi. I bought the EX7000 to extend the range of my wifi network. The problem is that when a device moves from the existing wifi network to the EX7000's extended wifi network then the MAC address changes to the virtual MAC address. The DHCP server CANNOT allocate/reserve a single IP address to multiple MAC addresses. Therefore the devices cannot keep the same DHCP-allocated IP address when moving across wifi networks. This is extremely frustrating. Why do we have to use virtual MAC addresses anyway?
I could manually set a static IP address on each device on the two saved wifi networks - but this defeats the purpose of having the DHCP server in the first place.
Is there a way to turn off the EX7000's Virtual MAC address feature or some other way to configure the above network so that devices can move between the wifi and extended-wifi networks whilst keeping their unique DHCP-allocated IP address?
- netwrksMaster
Check out the link below. If you have MAC Filtering enabled on your base router, just disable it. There is no Security in MAC Filtering. The best security is a strong password.
- maddavoTutor
Thanks, but the issue does not have to do with MAC Filtering. I do not use MAC filtering on my router. The issue is getting the right IP Address allocated to the right device (which is done by the DHCP server based on MAC Address). The DHCP server can only reserve a single IP address to a single MAC address - a one-to-one relationship. The 'Virtual' MAC Address causes devices to have multiple MAC Addresses which then means single static IP address allocation is not possible automatically as far as I can see.
- netwrksMaster
Yes, that's what the EX7000 and other extender's do. You can't remove the virtual mac address function. Not sure if it's an option for you, but the EX7000 does support AP mode.
- qnnskmnInitiate
That is true there is no security in Mac Filtering. However a "good" network admin would notice a spike on the network of a particular address then investigate. Why make it easier for those who want
to do harm?
- kochinApprentice
Netgear really needs to provide a way to turn Virtual MAC Address feature off. It creates problems on the network. When I move from one extender to the router, my device often fails to acquire an IP address due to the change of MAC. I wonder why Netgear needs to use Virtual MACs. Isn't MAC unique for a device?
- netwrksMaster
It turns off in AP mode (which you can't use). So yes, if you are trying to make this setup roam, you need to reserve an IP address to the virtual MAC address. The short version. For each connected client, the extender creates a separate session with the upstream Wireless Router. The Extender generates a virtual MAC on the Upstream side, virtual MAC that can be identified to keep sessions in check. NG is not the only vendor doing this, and is not the only vendor that does not allow disabling of the Virtual MAC function.
- kochinApprentice
Thank you for the detail explanation. I just don't understand why Vitural MACs are needed when MACs are unique. According to my observations, the EX7000 simply replaces the first 3 hex codes in the MAC with 02:0f:b5. I have 2 EX7000s, and both of them do the same thing with MACs. Why don't they just use original MACs?
When connected to my main router R7000, the original MAC is sent to my DHCP server (dnsmasq). When connected to an extender EX7000, a Virtual MAC is sent to the DHCP server. The switch-over seems to confuse some of my WiFi devices. Often they fail to obtain a new IP address and require an off-on cycle or even re-creating profile to obtain an IP address. And, they are not receiving the IP address I assigned due to Virtual MACs. Very frustrating.
Is there a technical reason for requireing Virtual MAC?
- kochinApprentice
I solved one of the problems with Virtual MAC addresses when running my own DHCP server. The DHCP server I am using is DNSMASQ on a Linux server. DNSMASQ actually allows mapping multiple MAC addresses to one IPv4 address.
For example, let's say aa:bb:cc:dd:ee:ff is the MAC address of a WiFi device and 192.168.x.y is the IP to be assigned to it. The Virtual MAC for that device on EX7000 should be 02:0f:b5:dd:ee:ff. So I use the following entry for it:
aa:bb:cc:dd:ee:ff,02:0f:b5:dd:ee:ff,192.168.x.y
The line is saved in a file /etc/dsnmasq-dhcphosts and loaded into DNSMASQ server. (Actually I am using OpenMediaVault with DNSMASQ plugin.) When a DHCP request for MAC address of either aa:bb:cc:dd:ee:ff or 02:0f:b5:dd:ee:ff is received, DNSMASQ server will lease the IP address 192.168.x.y to the requesting client.
Now no matter my WiFi device is connected to the main router or on of the extenders, it will receive the same pre-assigned IP address.
