bagattella's avatar
bagattella
EX7300 changes Wi Fi password by itself ?!?
After a lot of trial, I definitely gave connecting to 2,4 GHz network up.
5 GHz network works well, but I have some smartphones without that feature.
Connecting to the device by the apposite program, I discovered that the password is changed from the original one of the main modem router in a way like this:
3f46821e67cfe0b866ea126f01aa9940258615ee95e618bba01b3f7bd8fee0dd  (?!?)
while the original password is a mnemonic one.
Could somebody understand what happened?
And, more important, how can I fix it before returning the product to the seller?
Thanks
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello bagattella
    Have you tried to log into the extender and change the password to see if that one sticks?
    DarrenM
    • bagattella's avatar
      bagattella
      Hi DarrenM,
      thanks.
      Yes I tried to force that strange pwd to the right one connecting to the extender.
      It seemed to work: the smartphone connected but it doesn't work.
      It says "no internet connection". But the router was well working.
      I'm asking to myself if that extender were uncompatible with the Tecnhicolor router TG789vac Xtream 35b. Anybody heard something about it?
      Meanwhile I asked to the supplier to change the extender to exclude a failure of that device.
      Tomorrow I'm going to retry... :smileyfrustrated:
      PS: please, be patient for my bad english...
