Numismad's avatar
Numismad
ex7300v2 cannot extend signal from Linksys EA9500V1
Hello everyone!
router Linksys EA9500V1
2 wireless
2,4GHz and 5GHz
Security mode: WPA2 Personal
WPA2/WPA Mixed Personal
WPA2 Enterprise
WPA2/WPA Mixed Enterprise
WEP
I am trying to extend the signal by ex7300v2 (I have 2 pc) with the ANY settings:
WPA2-PSK [AES] or WPA-PSK [TKIP] + WPA2-PSK [AES]
but not successful:
Connect any WiFi enabled device like you would connect them to your main network, using the credentials below.
 I tried also to change firmware to the last version V1.0.0.146 but same.
I try to reset to the manufacture setting and again nothing.
But I have D-link chipper extenders and they are connecting without any problem. ((
Could you advise me, how to fix this problem?
thanks!
  • plemans's avatar
    Did you set it up using the push button WPS option?
    If so, factory reset the extender  and set it up using the installation assistant.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
    • Numismad's avatar
      Numismad
      Hi Plemans! Thank you for your attention,
      Yes I tried to use installation assistant
      but nothing, sometimes it's brought me only connection 5GHz
      Lynksys don't have WPS button, but I made experiment.
      I have another router - D-link Archer AX50 with WPS
      and after "Your extender has successfully connected to your existing WiFi network." (look screenshot pls)
      its brought ONLY 5GHz connection but 2.4 - not working....
      I think probably it's problem with firmware of ex7300v2? (
      Any ideas?
      Thanks!
      • plemans's avatar
        Your photo shows both connected.
        What firmware are you on for it?
