Banjo_on_Cable's avatar
Feb 14, 2018
EX7500 Configuration when Router does not support 5GHz
Just purchased my EX7500 and updated to the latest Firmware Version V1.0.0.38_1.0.54
My Cable Modem is a Netgear CG3000v2 which only support only 2.4GHz Wifi
Issues :
  • The Status Page shows the 2.4GHz has "(No Connection)"
  • The Status Page shows there is no 5GHz on the Router side, but it shows connection to the EX7500 over the 5GHz channel ( ? does it transfer the 5GHz traffic to 2.4GHz traffic on the Router-to-Extender connection ? )
  • The Start Page shows the 5GHz channel's Connection Status is Disconnected
  • If I disable the 5GHz channel on the EX7500, leaving only the 2.4GHz channel enabled,  then all traffic stops, the EX7500 is non-responsive, and I need to do a Factory Reset and start again
  • The display lights alternate a red light for 5GHz then 2.4GHz, then sometimes no 2.4GHz, although it still seems to operate --- there does not seem to be a strong correlation between the indicator lights and its operation.
  • Hi Banjo_on_Cable,
                                        2.4 and 5GHz on left panel of status indicates connectivity between your router and extender. If 5GHz shows not connected, either your router is not dual band or you haven't extended the 5GHz of router to this extender. 2.4 and 5GHz on right panel of status indicates connectivity between your devices and extender. If nothing is connected to either 1 of extender band, it'll show as not connected which doesn't mean your extender is not working. PFB link about LED status of this product.
    https://kb.netgear.com/000053099/What-do-the-LEDs-on-my-EX7500-Nighthawk-Tri-band-WiFi-Range-Extender-mean
    • Banjo_on_Cable's avatar
      Banjo_on_Cable
      As I stated in my original post, My Cable Modem is a Netgear CG3000v2 which only supports 2.4GHz Wifi
      So ...
      (1) There is no 5GHz channel from the modem/router to the EX7500, but the EX7500 Status Page shows as having the 5GHz channel is open for wireless connection, the status lights shows "blue" as active and porerational, but that seems to be somewhat problematic ... no 5GHz channel through to the modem/router
      (2) If I disable the 5GHz channel on the Setting Page and "save", the EX7500 "dies" with no communication possible, and I have to reset it to factory settings to restore its operation.
        Banjo_on_Cable
        As stated in my first post, the Firmware Version is  V1.0.0.38_1.0.54
