Nakiami's avatar
Nakiami
Guide
Aug 30, 2021
EX7700 Nighthawk X6 Extender limited to ~54mbps
I've got the EX7700 Nighthawk X6 Tri-band WiFi Mesh Extender set up as a wifi extender connected over 5GHz to my Archer VR1600v v2 router.
I can't get internet down speeds above ~54mbps.
Connecting to the router wifi directly gives me the expected 250mbps+ internet speed.
Looking at the Netgear UI, it claims to have a 866mbps connection to the router.
If i plug the EX7700 into the router using a cable, I get the desired speeds.
I have WMM enabled, and I'm using "802.11a/n/ac mixed" with WPA2-PSK+AES.
I have tried a hard reset and reconfiguration of both the router and EX7700.
I have the latest firmware on both the router and the EX7700 (V1.0.0.216). I also tried downgrading the firmware to V1.0.0.206, but that made no difference.
Any ideas?
  • the only other thing I'd try would be trying it on a different router.
    A friend/family member that you can try it on.
    If it doesn't work on that, then its a hardware issue and I'd open a support case.
    click on "mynetgear" at the top. from there you can register an account and the device. That'll let you check warranty/support
  • plemans's avatar
    what speed do you get if you hardwire into the extender?
    did you set it up using wps or using the installation assistant?
    • Nakiami's avatar
      Nakiami
      Guide
      Hi, thanks for your response. I have tried setting up the extender using
      1. the assistant in the browser
      2. the nighthawk app
      3. WPS.
      If I hardwire my computer to the extender, I get the same slow speed.
      • plemans's avatar
        do you have different router you could try it on?
        the 54mbps is what I'd expect from a 2.4ghz but not the 5ghz.
