delgado
Feb 18, 2020Tutor
EX8000 (AP) 5GHz Channels 116 and above do not work anymore
Hi there,
Lately I have a nasty issue with my EX8000 running as Access Point for two separate 5GHz SSID’s ... Usually the band with the 1700mbits sits on channel 100 - 112 which was working just fine. Lately I get forced channel switches because of DFS (this was definitely also the case before, but I just never noticed). The problem ist, if it changes to 116 and above, the Band seems dead. Not a single device can “see” this network anymore (all of them have 160MHz Support). If I use my backup fritz box and set the channel to >116 it’s working great... so for some reason the ex8000 antennas seem to stop working for 116 and above ...
I have done a factory reset already and I am using the most current firmware.
What region are you in?
what region is the extender set it?
What region are your devices in?
Reason I ask is different regions have different restrictions on DFS channels. If the region is set different from 1 device to the next, it can create issues or "unusable channels". Or even channels that are very low power for that region.
- delgadoTutor
its European Region and therefore channels up to 140 should be fine. As i wrote in my initial post, i tried with a different 5GHz Access Point and there i had no issues at all for the same Channels that refuse to work with the EX8000
delgado wrote:its European Region and therefore channels up to 140 should be fine. As i wrote in my initial post, i tried with a different 5GHz Access Point and there i had no issues at all for the same Channels that refuse to work with the EX8000
I understand that you've stated that region. do you have that region setup on the EX8000? AND on your devices accessing it?
