rcsimpson's avatar
rcsimpson
Follower
Aug 03, 2016
Help -New Router killed extender use
My range extender worked great for 2+ years.
THEN I changed routers.
I've tried  the factory reset - I've tried connecting an ethernet cable to the extender - every method i've found on line to get it to talk to my new network - Nothing works.
Does anyone have a suggestion - or better yet a foolk proof method?
thanks!
  • Io ho un problema simile. Mi connetto a mywifiext.net e avvio la procedura di collegamento all'access point, sembra procedere tutto bene ma alla fine viene sempre fuori un errore che non permette di finalizzare la procedura.
    L'access point è un plw1000. Col vecchio av200 nessun problema...
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello rcsimpson
      Make sure you are holding the reset button for 10 seconds when doing a factory reset also try changing the wireless channel on the router.
      DarrenM
