Yampow13
Nov 03, 2017Aspirant
Help with ac1900 R7000 nighthawk, cm600 cable modem, and ac2200 wifi extender
Would it be possible to run an ethernet cable from my cm600 cable modem to set nighthawk ac1900 R7000. Then connect an ethernet cable from my ac1900 to my ac2200 wifi range extender for the wifi. Wou...
TheEther
Nov 03, 2017Guru
It's fine to connect the ac2200 to the R7000 via LAN cable. You'll need to set the ac2200 to access point mode when you do this. Be sure to put some distance between the ac2200 and the R7000 and run them on different, non-overlapping Wi-Fi channels.
Yampow13
Nov 04, 2017Aspirant
If i run the ac2200 as access point do i have to put my ac1900 in bridge mode?
