rowekCSS's avatar
rowekCSS
Initiate
Aug 05, 2015
How to set IP address for WN3000RPv3 and make it keep
I really like my WN3000RPv3.  It gets the job done.  I did a quick setup which meant I allowed DHCP to set the IP address.  Now that I have more time I simply want to set the IP address manually.  I found the page in the NetGear Genie setup - Setup...IP Address Setup.   I clicked the radio button to "Use Static IP Address", the text boxes opened up as expected.  I entered the IP Address I wanted and pressed the "Apply" button.  It did not throw an error but it was over too quickly.  Normally the device needs a second or two before you can leave the screen as it applies the settings.  When I navigate away and then back the OLD IP Address that was assigned by DHCP is still there.
How do I make my new IP stick?
Thanks in advance.
Keith
