Kelbra813's avatar
Kelbra813
Follower
Sep 06, 2015
Iphone5 and WN2000RPT range extender
Lately the connection keeps dropping, when it used to work fine. It works fine with computer and Amazon Prime TV
  • Could you try changing the wireless channel of the router/extender, for the 2.4GHz band channels 1, 6, and 11 are typically the best choices? Are you using the 2.4GHz or 5GHz band?
1 Reply
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
