nir_melamoud
Aug 15, 2015Aspirant
is it really extending the Wifi or create a new one
I have a netgear EX6100's wifi extender, but it doe not extend my Wifi, it create a new one, here is what I expect it to do and what is really happening I put the original Wifi in my 1st floor, a...
nhann
Aug 18, 2015NETGEAR Employee Retired
Hi nir_melamoud,
Please see the following link to set up the same SSID for your network:
https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/Can-I-use-same-SSID-with-EX6100-as-the-R7000-router/m-p/971296#M9762
Let us know how it works for you.
NhanN
nir_melamoud
Aug 20, 2015Aspirant
I actually changed the configuration to be like that i.e I have two ssid's wirenir (for my original router and 2g network, and wirenir_5GEXT for the 5G network - I think its not working, here is why
1. im in area that I can not connect to wirenir but can connect to wirenir_5G - so it does not broadcast the wirenir to that area - BTW when I had separate 2G network that area worked great as well (so its not just 5G range vs 2G range)
2. the wizard warn me not to do that (same SSID as the router) -but I did it anyway, why is it not recommended - if it worked to extend the original router range it should be the default
3. when I walk with my phone connected to wirenir from an area that wirenir cover to an area that the extender's wirenir is covering I lose connectivity and get automaticaly connected to wirenir_5gext
I thought the feature is suppose to be done automatically (not by setting the SSID to be the same) when I check the "broadcase ssid checkbox" but maybe Im wrong - whats the purpose / meaning of this checkbox ?
- nhannAug 21, 2015NETGEAR Employee Retired
The loss of router connection and reconnection to extender is normal.
Depending on your device (tablet, pc, mac, etc) you can rank and prioritize your networks to automatically connect.If you disable broadcast of the SSID, only devices that have the correct SSID can connect. This means that the network is now hidden from devices unless you have the SSID.
- nir_melamoudAug 21, 2015Aspirant
so does it or does it not extend my ssid ? I know other devices that extend other SSID, that has no need for additional SSID (although they have that option) does your device does that or not ?
Just to be clear Extending my SSID mean that the extender broadcast the original router SSID and route all traffic through it to the original router, so there is no need to disconnect and connect when you walk through the house its the same network the extender suppose to be silent extender .
if your device does not have that functionality please say it clearly - yes or no ?
BTW the reason connect and disconnect is NOT NORMAL is that the phone will disconnect only if the signal level is really really low, but when it get half way through the bandwidth is really low and the device stop or almost stop working with the network, and only after a while or if you walk far enough it will actually disconenct and connect,
so I have areas in the house where I have no WIFI Im connected the the original router but the signal is not bad enough to disconnect and not good enough to actually work - bottom line its not working.
- netwrksAug 21, 2015Master
It doesn't roam the way you would like it to, as you are using it in Extender mode. The idea of an extender is, when you lose connectivity to your router's wireless network, you connect to the extender, that's why they suggest you keep the SSID's different,so you can connect from one to the other. Your best bet is to configure it as an Access Point - Page 16. The success of wireless client roaming, is based on the wireless client, not that AP.
