Bvia
Jul 24, 2016Follower
N300 Extender Shows as Connected but "No Internet Access"
Hello,
I am installing an N300 Range Extender for my Father-in-law and I have been able to connect the Extender to the router using the WPS button and all lights on the front of the extender show as being properly connected but when I connect devices to the _EXT Network the devices connect but say there is no internet access.
I have reset the router, surfboard and Range Extender and none of this has worked. Is there a common bug that anyone has seen an knows how to fix/workaround?
Thank you very much for any help that you can give!
Best Regards,
Beck
Is your router using MAC address access control? If so, you have to update its settings to permit devices connecting through the extender. Here is a direct link to the extender's manual instructions.
1 Reply
