lenena's avatar
lenena
Initiate
May 21, 2016
Need advice with my EX7000 and my BOX TV
Hello, I have a LIVEBOX ( Orange ). I turned OFF his Wifi and plug a ROUTEUR "Netgear R8000-100PES Nighthawk X6 AC3200 Tri-Band". In another room I have an extender "Netgear Nighthawk AC1900 EX7000-100PES" and need to plug on it by ETHERNET, a TV BOX. I tried everything and no images !!! I don't understand. I used to watch tv in this room using an AIRPORT EXTREME but the speed was so bad that I decided to buy the EX7000. I did a speed test on the REPETEUR, using an ethernet connection of the EX7000 and a laptop and the speed is wonderfull. I have something like 900/200 Mbps. So I don't understand why I don't manage to connect my TV BOX and see my tv.. Please any idea ? Thank you very much for your help.
  • IPTV service usually uses IP Multicast.  Log into your R8000, go to ADVANCED > Setup > WAN Setup, uncheck the Disable IGMP Proxying checkbox and click Apply.
    • lenena's avatar
      lenena
      Initiate
      I JUST CAN'T BELIEVE IT..... IT'S WORKIIIIIIIIIIIIIIIIIIIIIIG !!!!!! I don't know how to thank you because I was absolutely depressed and fighting since 15 days !!!!! 3 people ( I mean "expert"...) came without finding the problem... I 've changed all the materials three times...!!!! YOU ARE JUST MY HERO TODAY "TheEther".... THANK YOU VERY VERY VERY MUCH. You have all my gratitude ! :-))))
