TonyFG1971's avatar
TonyFG1971
Netgear EX2700 Poor Signal issues
Hi,
I’ve connected my Booster to my Router in my Lounge (Ethernet 100mb Internet) & home Network, with the Booster plugged in the my Sons bedroom (in same floor, as live in a Flat) so he can play online games with his friends, but the signal strength isn’t good enough so not happy . HELP pls.
Any ideas guys?
Cheers,
Tony
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
    Thank you.
  • michaelkenward's avatar
    michaelkenward
    TonyFG1971 wrote:
    Hi,
    What is that router?
    Is he using wifi or plugging into the Ethernet port on the EX2700?
    You might find that Powerline Ethernet is more reliable.
    • TonyFG1971's avatar
      TonyFG1971
      Thank you.
      I have a Virgin Hub 3 Router (Arris Group).
      Can I check that if my Router is in my Lounge & Booster in a Bedroom that it would be better to connect a cable from the Booster to my PS4 to improve the speed?
      Also, do Wi-Fi channels make a difference, as I’ve got everything set up auto channel optimise?
      This however doesn’t allow me to specify 2.4G instead of 5G which I believe is better when further away?
      Thanks,
      Tony
