bouch's avatar
bouch
Netgear Genie
I installed Netgear Genie and attempted to remote via phone. Page Device list "Select a router to manage remotely does not show my router although it is listed on previous page Log in to manage I am connected via phone to my wifi router?
  • Hi bouch,
    The Remote Login feature only works for NETGEAR supported routers and does not work with extenders and third party routers/gateways.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi bouch,
    Welcome to the community!
    1. What is the model number and firmware version of your device?
    2. This link provides a step by step process in setting up Remote Login for supported devices on the top right.
    Dexter
    Community Team
    • bouch's avatar
      bouch
      Thank You Dexter, The Router is an Huawei HG659 as supplied by my internet provider and I am trying to use a Netgear WiFi extender WN1000RP. I tried to do a connect using WPS buttons and when I do the Extender appears but then is followed by no internet connnection.
      I have attached device photo's.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi bouch,
      Dexter
      Community Team
