moose3473's avatar
moose3473
Initiate
Sep 17, 2018
NETGEAR N300 Wi-Fi Range Extender EX2700 Having issues with weak signal
Hello,
I currently have a Netgear N300 EX2700 WiFi Extender that I am using to extend coverage to my garage apt. where mother-in-law lives.  The extender is plugged into an outlet in garage and has a worked ok until recently.  I usually have a "good" signal strength on her tv but I know it varies throughout the day.  My question is, if I purchase another wifi extender of the same model and put one in her apt in addition to the one in the garage, would that help?   The location of my gateway is is close to center of house but it does have to travel through a few walls and brick to reach her apt. Tonight while she was on Amazon Prime it gave her a "insufficient bandwith" message on the screen. I've restarted gateway several times as well.  Any help would be appreciated.
Thank you!
Jason
  • StephenB's avatar
    While you can daisy-chain extenders, it's not a great approach.
    Is garage part of the house, or free-standing?
    There are several apps you can use to check signal strength.  Have you looked at the wifi signal strength of the extender network in her apartment?  If that signal strength is good, then adding an extender in her apartment won't help.
    Also, you can use the signal LEDs on the EX2700 (green/amber/red) to give you some idea on whether the issue is the link to the router, or the client link (to her devices).
    • moose3473's avatar
      moose3473
      Initiate
      Hey StephenB,
      Thanks for the info! It is a free standing garage. The signal from the router is good and all lights are green. She told me that it started working fine today so I’m not sure what the problem was. Can you send me the name of a couple of apps I can use to check the signal strength in her apt?
      Thanks for your help!
      Jason
