Neil4688
Jan 01, 2017Aspirant
Netgear N600 as a repeater?
I have an Apple Time Capsule connected to my Arris SB6141 modem. I have an additional Netgear N600 router that I want to connect to my network and use it as a wifi extender while also being able to ru...
Neil4688
To clarify I have the Netgear N600 in my basement. I have an Ethernet line already running downstairs from my Time Capsule so I need help with what settings to configure on the router itself and if I would need to configure anything on the main router as well.
DarrenM
Jan 09, 2017Sr. NETGEAR Moderator
Hello Neil4688
If you plug the ethernet into the WAN port of the router then go into the advanced settings setup and then LAN setup and uncheck use router as DHCP server you should be able to use it as a wireless AP.
DarrenM
