JohnnyFR
Sep 04, 2016Aspirant
netgear nighthawk x4 EX7300, leading to network performance issues
hello to all I have installed the nightwawk EX7300 wifi extender. the Wifi extension works fine but the original wifi signal is not working properly - the signal is identified - I can log into ...
DarrenM
Sep 06, 2016Sr. NETGEAR Moderator
Hello JohnnyFR
I would factory reset the extender try to do setup again. Make sure your router is using WPA2 security and also make sure your are using the latest firmware.
DarrenM
