JohnnyFR
Sep 04, 2016Aspirant
netgear nighthawk x4 EX7300, leading to network performance issues
hello to all I have installed the nightwawk EX7300 wifi extender. the Wifi extension works fine but the original wifi signal is not working properly - the signal is identified - I can log into ...
uconnbill
Jan 06, 2017Aspirant
Did you ever resolve this? I have the same issue... Extender works great. I lost the orginal access point and the ethernet connections in the original router don't work now. Frustrating.
- DarrenMJan 09, 2017Sr. NETGEAR Moderator
Hello uconnbill
Are you saying the ethernet does not work on your main router with the extender connected to it?
DarrenM
- JohnnyFRJan 10, 2017Aspirant
hello to both of you
I have never been able to fix this issue. I have rebooted, updated the software ...
Darren suggestion never worked for me :(
- uconnbillJan 10, 2017Aspirant
Yes, I connect the 7300 extender via WiFi (20 feet away) to my 6200 Router. I can access the extender...5G_5GEXT wifi, but not the original 5G WIFI access point on the router. Also, the physical internet connections on the router stop working.
When I unplug the extender and restart the router, router works fine again.
- DarrenMJan 12, 2017Sr. NETGEAR Moderator
Have you guys made sure the firmware is up to date on the router and the extender? Also have you tried to factory reset your router then set everything up again?
DarrenM
