JohnnyFR
Sep 04, 2016Aspirant
netgear nighthawk x4 EX7300, leading to network performance issues
hello to all I have installed the nightwawk EX7300 wifi extender. the Wifi extension works fine but the original wifi signal is not working properly - the signal is identified - I can log into ...
DarrenM
Jan 09, 2017Sr. NETGEAR Moderator
Hello uconnbill
Are you saying the ethernet does not work on your main router with the extender connected to it?
DarrenM
JohnnyFR
Jan 10, 2017Aspirant
hello to both of you
I have never been able to fix this issue. I have rebooted, updated the software ...
Darren suggestion never worked for me :(
